[mapguide-internals] MapGuide OSM Sample Project
Jason Birch
jason at jasonbirch.com
Sat Mar 27 13:00:38 EDT 2010
Someone could pipe it through FME (which supports all these formats) a
bit more easily :) Would have to somehow automate the process though,
so I guess licensing may be a concern. There are also some commandline
tools (like osm2pgsql) that could help get the data into a format we
can use with FDO. Sure would be nice to be able to start from SQLite
though.
Not sure of the value as a sample dataset. Much of MapGuide's value
proposition is in its server-side capabilities, and without structured
data (assessment, zoning, etc) this may be hard to showcase. OSM is a
greatbackdrop though. Would be great if we could take a region with
extensive open geodata (DC? Vancouver?) and bundle/maintain a
high-intelligence local sample using both OSM and local gov't data.
Jason
On 2010-03-27, Traian Stanev <traian.stanev at autodesk.com> wrote:
> A while back I started on some code to convert OSM data to FDO. I didn't
> finish coding it though, but I did get to the stage of parsing the XML and
> inserting a desired subset of attributes from it into a temporary SQLite
> database, which my plan was to convert to FDO SQLite format using a second
> conversion step (which would further classify the raw topology data, so you
> get a table for streets, a table for buildings, etc.)
> One piece of advice -- if you ever do this, use a custom stream reader which
> reads directly from the ZIP file using zlib and passes the decoded memory
> stream to your XML parser (I used libxml++, a lot better than Xerces IMO).
> This way you don't have to unzip the whole thing, and use up 120 Gigs on
> your drive.
> Traian
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor
> Wekel
> Sent: Saturday, March 27, 2010 11:30 AM
> To: MapGuide Internals Mail List
> Subject: RE: [mapguide-internals] MapGuide OSM Sample Project
> Hi Zac,
> I just did a bit of a pan around www.openstreetmap.org. Oh boy.
> - World wide coverage
> - Multiple languages (English, Russian, Arabic, Mandarin, other..)
> - Street level detail for Canada, USA, Europe, Russia, and more
> - Points of interest, building footprints in some area
> - The full dataset in OSM XML is a 13GB bzip compressed image
> The data is also covered under a non-restrictive license.
> Great suggestion. This is an impressive dataset. Anyone want to download
> it and convert it to SDF? I wonder if download.osgeo.org would let us post
> the whole dataset?
> Regards,
> Trevor
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: March 26, 2010 9:54 AM
> Subject: [mapguide-internals] MapGuide OSM Sample Project
> Hey everyone,
> I think it's high time we have a global OSM mapguide sample
> http://code.google.com/p/mapguide-osm
> who's interested in helping author a MGP for sample based off OSM data?
> z
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
