[mapguide-internals] /branches root directory reserved only for
MapGuide?
Trevor Wekel
trevor_wekel at otxsystems.com
Mon May 3 08:42:48 EDT 2010
I'm ok with using the existing branching mechanism. The branches should match the trunk layout.
/branches/2.1/Tools/Maestro
(Just add Tools/Maestro)
/branches/2.2/Installer
/branches/2.2/MgDev
(At some point we should set this branch up. Was hoping to get RFC 90 in first)
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: May 3, 2010 3:00 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] /branches root directory reserved only for MapGuide?
I think we discussed this when we were initially bringing Maestro in.
It was a while back, but I think the intention was to just use a
prefix for the Maestro branches (/branches/Maestro-2.1, etc...)
similar to how its done in tags.
On 2010-05-03, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Hi All,
> I'd like to make a "2.1" branch for Maestro since I plan to do some massive
> API changes/enhancements/overhauls post-2.1
> Can I put a 2.1 branch under the top-level "branches" svn directory? Or is
> this only for MapGuide's use?
> - Jackie
> http://osgeo-org.1803224.n2.nabble.com/branches-root-directory-reserved-only-for-MapGuide-tp4996834p4996834.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
