[mapguide-internals] svn checkout/update timeout
Trevor Wekel trevor_wekel at otxsystems.com
Mon May 10 06:40:09 EDT 2010
Hi Jackie,
Are you using TortoiseSVN for the checkout?  I get a similar message with Tortoise quite regularly.  The SVN command line tool seems to avoid this somehow.
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: May 10, 2010 3:21 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] svn checkout/update timeout
Hi All,
I've been trying to do a svn update on a pretty stale working copy from one
of my work machines. But I've keep getting the following error message:
Error: REPORT of '/mapguide/!svn/vcc/default': Could not read response body:
Error: connection was closed by server (http://svn.osgeo.org)
It seems it dies when the item being updated or checked out is quite large
(FYI: I am trying to update MgDev\Oem which has quite a few large files).
The connection seems to die 14-15MBs into the checkout/update.
Has anybody else experienced such issues like this? I can do large
checkouts/updates just fine from my home machine.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/svn-checkout-update-timeout-tp5029643p5029643.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
