[mapguide-internals] RE: svn checkout/update timeout
Haris Kurtagic
haris at sl-king.com
Mon May 10 08:51:00 EDT 2010
I always had this issue. Never managed to get OEM in one try. My solution
was to repeat svn update few times before getting all code.
Haris
On Mon, May 10, 2010 at 1:22 PM, Trevor Wekel
<trevor_wekel at otxsystems.com>wrote:
> Hmm... Switching to the command line made it more stable for me. You could
> always set up a local mirror to grab the original source and then relocate
> to the main OSGeo server.
> Trevor
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:
> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: May 10, 2010 5:14 AM
> To: mapguide-internals at lists.osgeo.org
> Subject: [mapguide-internals] RE: svn checkout/update timeout
> Hi Trevor,
> Yes I normally use TortoiseSVN. I get this same behaviour from the
> command-line however.
> - Jackie
> http://osgeo-org.1803224.n2.nabble.com/svn-checkout-update-timeout-tp5029643p5030033.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
