[mapguide-internals] RE: svn checkout/update timeout
Zac Spitzer zac.spitzer at gmail.com
Mon May 10 21:14:01 EDT 2010
it will resume, do a svn cleanup if you get errors
On 11 May 2010 11:03, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Hi Haris,
> Does svn resume from the point of failure? I get the impression it doesn't.
> Like I said before, svn update will die at around the 14-15mb mark, so
> unless there's a 100+mb file in Oem I would've thought repeated attempts
> would have powered through.
> - Jackie
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/svn-checkout-update-timeout-tp5029643p5033874.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals mailing list
