[mapguide-internals] Re: Mapguide Maestro speaks Croatian
Tom Fukushima tom.fukushima at autodesk.com
Fri May 21 08:06:06 EDT 2010
I can confirm that Ivan doesn't have write access; but if you give the details of the type of access you need:  e.g., write access to Maestro repository for updating localization related problems.  I would think that approval could be quite quick.
Ivan, you would also need to send in a signed contributor agreement found on this page: http://mapguide.osgeo.org/developer.html
Thanks
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Ivan Milicevic
Sent: Friday, May 21, 2010 4:56 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Re: Mapguide Maestro speaks Croatian
I would also prefer svn but I think that I don't have write access to the repository.
Tickets for undersized buttons will be created.
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Friday, May 21, 2010 10:42 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Re: Mapguide Maestro speaks Croatian
If you have svn write access, I would prefer you do it yourself if you know
what to do. Otherwise email or trac tickets for translation files and I'll
do it myself.
Also it would be helpful to create trac tickets for UI localization problems
such as the under-sized button.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Kenneth-is-leaving-MapGuide-tp4714748p5083322.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
