[mapguide-internals] RE: Motion: Commit rights for Andre Barth
Robert Bray
robert.bray at autodesk.com
Fri Nov 12 00:19:54 EST 2010
+1 Bob
----- Original Message -----
From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
Sent: Thu Nov 11 21:13:53 2010
Subject: [mapguide-internals] RE: Motion: Commit rights for Andre Barth
+1 Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce Dechant
Sent: November 11, 2010 6:22 PM
Subject: [mapguide-internals] Motion: Commit rights for Andre Barth
I would like to extend Andre Barth's rights so he can submit to the MapGuide trunk depot.
Andre would be contributing to the coordinate system MgCoordinateSystem API that is a wrapper around the CsMap API.
Andre is already a committer to the CsMap depot and the goal of his activity on the coordinate system API is to expose CsMap functionalities to MapGuide's API
On the CsMap side, he's been assisting Norm Olsen this past year while the RFC2 was designed:
http://trac.osgeo.org/csmap/wiki/CsMapRfc2
He then worked on the CsMap test suite to identify regressions triggered by the redesign (a regression in that code would also mean eventually a regression in MapGuide's code, so this work was critical)
This CsMap RFC2 re-engineering work led to the MapGuide RFC94 to open the functionality to the rest of the public API:
http://svn.osgeo.org/mapguide/sandbox/rfc94/
The software design for the RFC94 was provided by Andre as well as the implementation, and then reviewed by Norm Olsen.
The code was developed and submitted by Andre to the sandbox for the RFC94 where he had commit rights:
Once done, the RFC94 sandbox was then merged into the MapGuide trunk, and this was done by Norm Olsen who has commit rights to the trunk.
This work lead to the creation of the following interfaces and their implementation behind:
MgCoordinateSystemGeodeticAnalyticalTransformationMethod
MgCoordinateSystemGeodeticAnalyticalTransformDefParams
MgCoordinateSystemGeodeticInterpolationTransformDefParams
MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod
MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams
MgCoordinateSystemGeodeticPath
MgCoordinateSystemGeodeticPathDictionary
MgCoordinateSystemGeodeticPathElement
MgCoordinateSystemGeodeticTransformDef
MgCoordinateSystemGeodeticTransformDefDictionary
MgCoordinateSystemGeodeticTransformDefParams
MgCoordinateSystemGeodeticTransformDefType
MgCoordinateSystemGeodeticTransformGridFile
MgCoordinateSystemGeodeticTransformGridFileFormat
The existing implementation behind the interface MgCoordinateSystemGeodeticTransformation was reworked to handle backward compatibility while still enabling the new functionality exposed through the new interfaces.
The submission 5164 "Merging the sandbox RFC94 to the trunk" lists all the source that was involved in this work:
http://trac.osgeo.org/mapguide/changeset/5164
As said above, the code was originally inside the sandbox http://svn.osgeo.org/mapguide/sandbox/rfc94/
This shows the amount of work executed by Andre, 38 new source code files and 33 modified existing files listed at the URL mentioned above.
Another example of a code submissions performed by Norm Olsen and written by Andre is:
Submission 5241 "adding Useful Range capability to the Geodetic Transformation API"
http://trac.osgeo.org/mapguide/changeset/5241
Other recent activities on the MapGuide project, still within the coordinate system engine area were:
- Log and fix ticket 1468, Unset the EPSG code when cloning a Coordinate System entity
http://trac.osgeo.org/mapguide/ticket/1468
- Log and fix ticket 1463 - Access to the CsMap coordinate system dictionary files is not correctly protected by the Mg API
http://trac.osgeo.org/mapguide/ticket/1463
As you can see all this work is centralized around the coordinate system engine.
Working closely with Norm Olsen and Hugues Wisniewski (the Osgeo lead for the CS-Map project), judging from his motivation, the high quality of his work and his commitment to a job well done, I am confident that Andre will be of a great help on the MapGuide team in the future.
+1
Thanks,
Bruce
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
