[mapguide-internals] PATCH 1468: "Unset the EPSG code when cloning a Coordinate System entity"
Bruce Dechant bruce.dechant at autodesk.com
Tue Oct 19 12:22:11 EDT 2010
André,
Thanks for creating a patch for this enhancement.
I'll review it and submit it on your behalf.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Andre Barth
Sent: Monday, October 18, 2010 1:43 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] PATCH 1468: "Unset the EPSG code when cloning a Coordinate System entity"
Hi all,
can you please have a look at patch 1468 http://trac.osgeo.org/mapguide/ticket/1468 and the patch attached to it.
It's a rather minor enhancement in how the EPSG code is handled when a coordinate system entity (i.e. ellipsoid, datum, coordinate system, geodetic transformation, geodetic path) is cloned/duplicated. Currently, CsMap's NameMapper component does not consider the EPSG code anyway that might have been stored with a definition in one of the dictionaries but rather uses the static information that's built into it (See MgCoordinateSystemFactory::CreateFromCode).
Cloning an CS entity and then writing it back to the dictionaries makes it editable (unlike to the definitions that are built by CsMap's dictionary compiler) - i.e. the parameters can modified and written back. Unsetting the EPSG code after a CreateClone() reduces the likelihood of 'chaos' in the dictionaries where the same EPSG code exists for varying definitions.
Thanks,
André
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
