[mapguide-internals] Memory leakage in WebTier (Java)
Bruce Dechant bruce.dechant at autodesk.com
Wed Sep 1 16:15:46 EDT 2010
Andreas,
In the case you have below if you Release the MgByteReader object before the src object gets GCed it will reduce the reference count to 0 and call the Dispose method to delete the object properly. It looks like you are getting the MgByteReader object and hanging on to it past the lifetime of the src object.
Is it possible to alter your code so that you change the sequence to finish using the MgByteReader object before you go out of scope for your src object?
In general readers should be cleaned up as soon as you are finished with them.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Andreas Morf
Sent: Wednesday, September 01, 2010 2:00 PM
To: 'MapGuide Internals Mail List'
Subject: RE: [mapguide-internals] Memory leakage in WebTier (Java)
Bruce,
I am using a 2.2 (trunk) compiled with vc10 - the only difference is that i
updated to the newest versions of ACE, dbxml and geos. Indeed, mgserver is
really stable and fast (plus 20-30% compared to 2.1) with all optimisations
activated in vc project options.
Back to the example mentioned in my first email: can you explain me, how the
orphaned c++ objects (which are not on the java heap) are freed/deleted
after the java (SWIG) objects are gc'd?
Andreas
-----Ursprüngliche Nachricht-----
Von: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] Im Auftrag von Bruce
Dechant
Gesendet: Mittwoch, 1. September 2010 21:34
An: MapGuide Internals Mail List
Betreff: RE: [mapguide-internals] Memory leakage in WebTier (Java)
Andreas,
That is odd - under load testing without the setting below I would easily
see the java heap get dangerously close to 2GB, but with the change it stays
around 100MB or so.
So it fixed the memory leak issues I was seeing with MGOS 2.2
My next question is what version of MGOS are you using?
The 2.2 release is really stable compared to 2.1 and prior releases.
Thanks,
Bruce
Morf
Sent: Wednesday, September 01, 2010 1:27 PM
Bruce,
I recently installed tomcat 6.0.29 and inserted your suggested entry -
unfortunately leakage remains the same. The java heap is not increasing and
the memory profiler shows that the orphaned MgXXX objects are allocated by
Mg-dll's.
Thanks,
Andreas
Dechant
Gesendet: Mittwoch, 1. September 2010 18:00
Andreas,
What version of Tomcat are you using?
I ask because there is a known Tomcat issue with memory leak prevention not
being enabled by default.
Regardless, please check that the following entry is in the Tomcat
server.xml file. This entry fixes lots of Java memory leaks.
  <!-- Prevent memory leaks due to use of particular java/javax APIs-->
  <Listener
className="org.apache.catalina.core.JreMemoryLeakPreventionListener" />
Thanks,
Bruce
Morf
Sent: Wednesday, September 01, 2010 7:12 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Memory leakage in WebTier (Java)
Hi all
I'm intensively using the java webtier and with more users accessing
mapguide this is getting a real problem:
After every call to a servlet using MgApi the memory consumption of
javaw.exe (tomcat) is increasing even after GC. I used a memory
profiler on javaw and saw that almost all the MgXXX objects remain in
memory.
After some more investigations with the debugger I remarked the following
pattern which I can describe on an example:
MgByteSource src = new MgByteSource(b, b.length);
MgByteReader layerDefContent = src.GetReader();
When gc deletes the src-object the MgGuardDisposable::Release() is called by
JNI. Because of the 'src.GetReader()' call m_refCount
has a value of 2, so 'Release()' just decreases it by 1 and returns to JAVA
without calling the Dispose() method of MgByteSource. So
the java-object is deleted while the C++ object remains orphaned in memory.
This pattern is happening with almost every MgApi usage and my
LoadMap-Servlet which creates a new MgMap and saves all Layers with a
filter to the Session-Repository every run leads to a leakage of around 5MB
(MgMap has quite a large cascade of (not just small)
child objects).
Can anyone confirm my diagnosis and maybe give a hint where/how to fix this
problem and is this maybe a general memory management
issue?
Greets, Andreas
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
