[mapguide-internals] MapGuide RFC 104 - Support Visual Studio
2010 has been updated
Christine Bao
Christine.Bao at autodesk.com
Thu Apr 14 03:15:08 EDT 2011
Hi all,
The patch for RFC http://trac.osgeo.org/mapguide/wiki/MapGuideRfc104 is attached for review. It adds Visual Studio 2010 projects side by side with Visual Studio 2008 project. A few code files are modified to adopt Visual Studio 2010 syntax. It's test against Visual Studio 2008 that all projects work as before and not impacted by this porting.
Thanks & regards,
Christine
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Mars Wu
Sent: Monday, April 11, 2011 10:07 AM
To: MapGuide Internals Mail List (mapguide-internals at lists.osgeo.org)
Subject: [mapguide-internals] MapGuide RFC 104 - Support Visual Studio 2010 has been updated
Hi all,
Based on our discussion for this post: http://osgeo-org.1803224.n2.nabble.com/Request-Feedback-Support-Vistual-Studio-2010-td6225690.html
The adopted RFC 104 has been updated to reflect the change. The change was added in the "Addendum" section of RFC104 as:
The project files used by Visual Studio 2010 will use the VC100 compiler/linker and the project files used by Visual Studio 2008 will be kept and still use the VC90 compiler/linker
If there is no objection, we will start to submit changes from this Wednesday (2011/04/13).
Thanks,
Mars
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
