[mapguide-internals] RE: Motion: Commit rights for Mars Wu
andSpark Liu
Trevor Wekel
trevor_wekel at otxsystems.com
Fri Aug 5 11:46:43 EDT 2011
+1 Trevor
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: August 5, 2011 12:26 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] RE: Motion: Commit rights for Mars Wu andSpark Liu
+1
Haris
On Fri, Aug 5, 2011 at 3:38 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> +1 Zac
> On Fri, Aug 5, 2011 at 2:26 AM, Bruce Dechant
> <bruce.dechant at autodesk.com> wrote:
>> I have received the committer agreements from both Mars and Spark.
>> So if there are no further comments I would like to proceed with giving them commit rights.
>> Thanks,
>> Bruce
>> PS. If there are more comments about the coding guidelines can you please create a new thread instead of derailing this one :)
>> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Walt Welton-Lair
>> Sent: Friday, July 29, 2011 11:34 AM
>> Subject: RE: [mapguide-internals] RE: Motion: Commit rights for Mars Wu andSpark Liu
>> Thanks Jon for pointing this out. That's a mistake in the document. I've corrected it.
>> Walt
>> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jonathan Rizzo
>> Sent: Friday, July 29, 2011 11:20 AM
>> Minor detail, but I was reading over the coding standards and I found an incorrect statement about Try-Catch Statements:
>> "A try-catch statement may also be followed by finally which is always executed (unless an exception is thrown in the body of an executed catch)."
>> In fact, finally WILL execute even if an exception is thrown in the body of an executed catch. I use this technique quite often to "clean up" in the event of an exception but still pass the exception up the stack.
>> A minor point, I know, but I thought I should point it out.
>> Jon
>> Sent: Thursday, July 28, 2011 1:20 PM
>> Subject: [mapguide-internals] RE: Motion: Commit rights for Mars Wu andSpark Liu
>> As long as they have read and understood the coding standards
>> (https://trac.osgeo.org/mapguide/wiki/MapGuideCodingStandards) then I support this.
>> Walt
>> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce Dechant
>> Sent: Thursday, July 28, 2011 11:56 AM
>> To: MapGuide Internals Mail List (mapguide-internals at lists.osgeo.org)
>> Subject: [mapguide-internals] Motion: Commit rights for Mars Wu and Spark Liu
>> Hi All,
>> I'd like to propose that we grant subversion commit rights for the MapGuide vault to Mars Wu and Spark Liu.
>> They are Autodesk developers working in Shanghai, and have made numerous defect fixes and enhancements to the code base over the last few years.
>> Mars Wu has worked on MGOS for more than 2 years. Here is a summary of the tickets, changesets and RFC he has done:
>> RFC:
>> - MapGuide RFC 96 - QuickPlot solution for both Ajax and Fusion
>> viewers<http://trac.osgeo.org/mapguide/wiki/MapGuideRfc96>
>> Tickets:
>> - #1412<http://trac.osgeo.org/mapguide/ticket/1412> Implement
>> RFC 96 - Quick Plot solution for
>> fusion<http://trac.osgeo.org/mapguide/ticket/1412>
>> - #1414<http://trac.osgeo.org/mapguide/ticket/1414> Implement
>> ajax<http://trac.osgeo.org/mapguide/ticket/1414>
>> - #1435<http://trac.osgeo.org/mapguide/ticket/1435> IE8: Map
>> context menu doesn't work after Quick Plot is invoked<http://trac.osgeo.org/mapguide/ticket/1435>
>> - #1443<http://trac.osgeo.org/mapguide/ticket/1443>
>> MgProxyFeatureService::GetCapabilities is using a fixed api version 1.0.0<http://trac.osgeo.org/mapguide/ticket/1443>
>> - #1589<http://trac.osgeo.org/mapguide/ticket/1589> Ajax Quick
>> Plot: Capture box cannot move or rotate when base layers exist<http://trac.osgeo.org/mapguide/ticket/1589>
>> - #1757<http://trac.osgeo.org/mapguide/ticket/1757> Quick Ploat
>> cannot generate map picture in some non-English locale<http://trac.osgeo.org/mapguide/ticket/1757>
>> - #1521<http://trac.osgeo.org/mapguide/ticket/1521> Use mouse
>> wheel to zoom map in the "Digitize"
>> process<http://trac.osgeo.org/mapguide/ticket/1521>
>> - #1539<http://trac.osgeo.org/mapguide/ticket/1539> Script
>> error when closing IE window / tab with the Quick Plot preview dialog open in Ajax viewer<http://trac.osgeo.org/mapguide/ticket/1539>
>> - #1546<http://trac.osgeo.org/mapguide/ticket/1546> Ajax quick
>> plot enhancements: mouse cursor and event controlling<http://trac.osgeo.org/mapguide/ticket/1546>
>> - #1585<http://trac.osgeo.org/mapguide/ticket/1585> Zoom
>> Rectange doesn't work properly in Ajax
>> viewer<http://trac.osgeo.org/mapguide/ticket/1585>
>> Changesets:
>> - 6012<http://trac.osgeo.org/mapguide/changeset/6012>
>> - 6010<http://trac.osgeo.org/mapguide/changeset/6010>
>> - 5509<http://trac.osgeo.org/mapguide/changeset/5509>
>> - 5507<http://trac.osgeo.org/mapguide/changeset/5507>
>> - 5501<http://trac.osgeo.org/mapguide/changeset/5501>
>> - 5430<http://trac.osgeo.org/mapguide/changeset/5430>
>> - 5512<http://trac.osgeo.org/mapguide/changeset/5512>
>> - 5411<http://trac.osgeo.org/mapguide/changeset/5411>
>> - 5394<http://trac.osgeo.org/mapguide/changeset/5394>
>> - 5152<http://trac.osgeo.org/mapguide/changeset/5152>
>> - 5132<http://trac.osgeo.org/mapguide/changeset/5132>
>> - 5098<http://trac.osgeo.org/mapguide/changeset/5098>
>> - 5097<http://trac.osgeo.org/mapguide/changeset/5097>
>> - 5095<http://trac.osgeo.org/mapguide/changeset/5095>
>> - 4091<http://trac.osgeo.org/mapguide/changeset/4091>
>> Spark has worked on MGOS for more than 2 years. Here is a summary of the tickets, changesets and RFC he has done:
>> RFC:
>> - 108 Support
>> Watermark<http://trac.osgeo.org/mapguide/wiki/MapGuideRfc108>
>> Tickets:
>> - 1514 Ctrl+Click can't end digitize LineString in Chrome on
>> Windows<http://trac.osgeo.org/mapguide/ticket/1514>
>> - 1527 Rendering fails if the map references to a not-exist
>> resource<http://trac.osgeo.org/mapguide/ticket/1527>
>> - 1553 Ctrl+Click at first when "selecting polygon" shows error
>> message in Safari / Chrome<http://trac.osgeo.org/mapguide/ticket/1553>
>> - 1605 There is no Serializable attribute for C# wrapper of any
>> exception class which make the exception can't get across the AppDomain<http://trac.osgeo.org/mapguide/ticket/1605>
>> - 1728 Fetch size is not set when using command even when
>> DataCacheSize configuration is
>> set<http://trac.osgeo.org/mapguide/ticket/1728>
>> - 1752 Misuse column name instead of column index during data
>> reader's serialization<http://trac.osgeo.org/mapguide/ticket/1752>
>> - 1756 ServerFeatureService.DescribeSchemaAsXml will throw
>> exception when geometry property is inherited from base class<http://trac.osgeo.org/mapguide/ticket/1756>
>> - 1762 Connect always shows "Cannot parse XML document whose
>> stream is at end-of-file." when setting
>> configuration<http://trac.osgeo.org/mapguide/ticket/1762>
>> Changesets:
>> - 6011<http://trac.osgeo.org/mapguide/changeset/6011>
>> - 5999<http://trac.osgeo.org/mapguide/changeset/5999>
>> - 5988<http://trac.osgeo.org/mapguide/changeset/5988>
>> - 5949<http://trac.osgeo.org/mapguide/changeset/5949>
>> - 5557<http://trac.osgeo.org/mapguide/changeset/5557>
>> - 5556<http://trac.osgeo.org/mapguide/changeset/5556>
>> - 5458<http://trac.osgeo.org/mapguide/changeset/5458>
>> - 5444<http://trac.osgeo.org/mapguide/changeset/5444>
>> - 5393<http://trac.osgeo.org/mapguide/changeset/5393>
>> - 5367<http://trac.osgeo.org/mapguide/changeset/5367>
>> - 5366<http://trac.osgeo.org/mapguide/changeset/5366>
>> - 5365<http://trac.osgeo.org/mapguide/changeset/5365>
>> - 5302<http://trac.osgeo.org/mapguide/changeset/5302>
>> - 5290<http://trac.osgeo.org/mapguide/changeset/5290>
>> - 5237<http://trac.osgeo.org/mapguide/changeset/5237>
>> - 5220<http://trac.osgeo.org/mapguide/changeset/5220>
>> - 5168<http://trac.osgeo.org/mapguide/changeset/5168>
>> - 5139<http://trac.osgeo.org/mapguide/changeset/5139>
>> - 4461<http://trac.osgeo.org/mapguide/changeset/4461>
>> I would like to motion for a vote on giving Mars Wu and Spark Liu commit rights to the MapGuide vault.
>> +1 Bruce
>> Thanks,
>> Bruce
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>> This electronic transmission may contain confidential, proprietary or privileged information. No confidentiality or privilege is intended to be waived or lost by erroneous transmission of this message. If you receive this message in error, please notify the sender immediately by return email and delete this message from your system. Disclosure, use, distribution or copying of this message, any attachments thereto or their contents is strictly prohibited.
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
More information about the mapguide-internals
