[mapguide-internals] RE: IPv6 support mandatory?
Zac Spitzer zac.spitzer at gmail.com
Thu Dec 1 21:53:05 EST 2011
any luck with this? we ran into some other issues after enabling ipv6
on a 2003 server
On Tue, Sep 13, 2011 at 1:12 PM, Mars Wu <mars.wu at autodesk.com> wrote:
> Hi Jackie,
> Then that's a little bit strange. I have to debug to see what's the problem. I will let you know the result.
> Thanks,
> Mars
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Tuesday, September 13, 2011 11:11 AM
> To: mapguide-internals at lists.osgeo.org
> Subject: [mapguide-internals] RE: IPv6 support mandatory?
> Hi Mars,
> The IP address that I had in the serverconfig.ini was just the IPv4 loopback (ie. 127.0.0.1).
> - Jackie
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/IPv6-support-mandatory-tp6782335p6786045.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals mailing list
