[mapguide-internals] Session repository lock under
multi-threaded update
Bruce Dechant
bruce.dechant at autodesk.com
Wed Jan 5 17:53:09 EST 2011
This would also apply to DBXML 2.3.10 used in MGOS 2.2 and MGE 2011.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Wednesday, January 05, 2011 3:48 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Session repository lock under multi-threaded update
Ok. Thanks Bruce, Thanks Andreas.
Would this also apply to DBXML 2.3.10 used in MGE 2011 and MGOS 2.2, or is it strictly DBXML 2.5.16 related?
Regards,
Trevor
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce Dechant
Sent: January 5, 2011 3:45 PM
The problem is that DBXML 2.5.16 always uses a transaction when doing dbxml operations.
Our resource service was for some operations not creating a transaction and this in turn caused dbxml to create one internally - this can be problematic and may have caused the lockups you are seeing. I remember seeing this while doing the dbxml upgrade. I changed the resource service code to follow the dbxml guidelines to always use a transaction for all dbxml operations. With this change the lockups went away. I tested with between 20 and 100 concurrent user loads over the weekend (48+ hours) and there were no lockups and with the new session repository strategy I didn't see any DB_BUSY errors either.
Thanks,
Bruce
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Andreas Morf
Sent: Wednesday, January 05, 2011 3:11 PM
To: 'MapGuide Internals Mail List'
Trevor,
I saw this many times when I was upgrading to dbxml 2.5.16 which is
especially more sensitive when being called by an untransacted
dbxml-API-operation. After eliminating these in MgResourceService there are
DB_BUSY errors sometimes which I was able to handle in my JAVA Webapi code -
but in my opinion, this could/should be handled by MgResourceService in a
better way...
Andreas
-----Ursprüngliche Nachricht-----
Von: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] Im Auftrag von Trevor
Wekel
Gesendet: Mittwoch, 5. Januar 2011 22:19
An: MapGuide Internals Mail List
Betreff: [mapguide-internals] Session repository lock under multi-threaded
update
Hello,
Has anyone experienced session repository lockup when executing 4+
concurrent calls to SetResource using different session ids? The
SetResource call is creating new resources and not updating old resources.
Thanks,
Trevor
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
