[mapguide-internals] Fusion refers to an external server - spatialreference.org which is offline
Jason Birch jason at jasonbirch.com
Fri Jan 7 13:27:04 EST 2011
The site is down because it was causing reliability issues for the
server it was hosted on in late december (see the openlayers dev
mailng list)
I don't think we should have a dependency on spatialreference.org, not
because it's external but because--as useful as it is--it's just a
utility site put up by two members of the community. It's not
advertised as a reliable service, and we shouldn't be using it as such
without clearing that use with the maintainers first (and likely
contributing time/money to turning it into a reliable service).
Jason
On 2011-01-07, Dave Wilson <dave.wilson at autodesk.com> wrote:
> It looks like their website name has changed. There is a hyphen in the name
> currently for the working website. A Google search only shows listing for
> the non-hyphenated name.
> http://spatial-reference.org
> Maybe they are on a backup site or they are in transition. There is no
> notice to indicate why the name has changed.
> I too questioned the use of such an embedded reference a while back, but I
> don't think we came to any conclusion about continuing to include it or not.
> If your site is purely internal do you want to reference an external site?
> And now the scenario where the site is referenced and "it's down".
> Dave
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Michael
> Adair
> Sent: Friday, January 07, 2011 7:36 AM
> To: mapguide-internals at lists.osgeo.org
> Subject: Re: [mapguide-internals] Fusion refers to an external server -
> Zac,
> That is the Proj4js library trying to find the projection definitions
> for EPSG:28355 and it only goes to spatialreference.org as the last
> resort, and that is really only for cases where you don't know what
> projections you app will be using.  When you do know what projections
> you will be dealing with, you can put the definiton in your JavaScript
> somewhere, eg. (substitute you own EPSG code and data):
> <script type="text/javascript" src="EPSG42304.js"></script>
> where that file contains the Proj.4 init string:
> Proj4js.defs["EPSG:42304"]="+title=Atlas of Canada, LCC +proj=lcc
> +lat_1=49 +lat_2=77 +lat_0=49 +lon_0=-95 +x_0=0 +y_0=0 +ellps=GRS80
> +datum=NAD83 +units=m +no_defs";
> If that Proj4js.defs value is not found, it then looks in a directory
> for the file automatically ('/lib' I think?)  and if not found there it
> looks on spatialreference.org.
> Fusion trunk includes the latest Proj4js which can also parse the
> projection initialization from the WKT returned by MapGuide so you don't
> need to include the init string.  That part can use more testing to make
> sure all the WK cases get tested.
> Mike
> On 07/01/2011 12:08 AM, Zac Spitzer wrote:
>> Just been playing with 2.2 RC2,
>> I noticed that fusion is trying to access
>> http://spatialreference.org/ref/epsg/28355/proj4js/
>> a website which is offline at the moment,
>> should we really be dependant on third party websites?
>> can we use a local call to CS-MAP instead?
>> z
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
