[mapguide-internals] RFC90 metatiling progress
Zac Spitzer
zac.spitzer at gmail.com
Thu Jul 21 00:39:53 EDT 2011
Can anyone shed some insight on the inter-service dependencies question?
On Wed, Jun 29, 2011 at 8:16 PM, UV <uvwild at googlemail.com> wrote:
> Hello,
> I commited my changes to the new branch and added some comments to the
> rfc90 page in Trac.
> If someone cares to have a look I am happy to integrate those remarks for
> my final contribution.
> I integrated most of Trevors suggestions below, more to come.
> I would appreciate a general statement regarding inter-service
> dependencies.
> Adding the rfc90 functionality forced me to include the rendering service
> from the tile service to access the additional code.
> I am open for suggestions how to avoid such dependencies without
> duplicating code unnecessarily.
> Kind Regards,
> UV
> On 6/11/2010 18:22, Trevor Wekel wrote:
>> Hi UV,
>> A couple of comments below. We can schedule time for a chat session.
>> When are you available?
>> GetTileCoords() move to MgMap
>> - Other use cases include programmatic calculation of tile location by
>> external applications.
>> DetectLockFile() move to MgTileCache
>> - The locking mechanism (whatever it happens to be) is for tiles and
>> should be encapsulated/hidden accordingly.
>> - I will also look into ACE::Conditions. It's always better to have ACE
>> do the work for us...
>> Regards,
>> Trevor
>> -----Original Message-----
>> From: mapguide-internals-bounces@**lists.osgeo.org<mapguide-internals-bounces at lists.osgeo.org>[mailto:
>> mapguide-internals-**bounces at lists.osgeo.org<mapguide-internals-bounces at lists.osgeo.org>]
>> On Behalf Of UV
>> Sent: November 5, 2010 4:36 AM
>> To: MapGuide Internals Mail List
>> Subject: Re: [mapguide-internals] Initial review on RFC90 code
>> Hi Trevor,
>> I finally managed to get back to this and are currently working to
>> resolve some of the mentioned issues.
>> Thanks a lot for the comments.
>> However, some comments are not 100% clear to me or there is a config
>> reason behind.
>> I think a direct chat session would be a most efficient way to sort out
>> the remaining issues.
>> I am on CET now and have time for a few days between changing jobs.
>> Comments on each issue inline below.
>> On 27/04/2010 20:09, Trevor Wekel wrote:
>>> Hi UV,
>>> Here are some comments from my initial review of the RFC 90 code. I will
>>> do a follow up review once the RFC has been updated and code changes have
>>> been made.
>>> Thank you,
>>> Trevor
>>> General Comments
>>> RFC 90 documentation in Trac is incomplete. All serverconfig.ini
>>> parameters and new function signatures should be documented. A general
>>> algorithm overview would also be good.
>>> Based on my initial review, the following items should be documented:
>>> - useMetaTiles and LockMethod serverconfig.ini parameters.
>>> - Behavioural modification to AGGRenderer::Save and AGGImageIO.cpp
>>> - New MgTileCache behaviour (see below, I believe some refactoring would
>>> be appropriate)
>>> File specific comments
>>> RenderingService.h
>>> ProxyRenderingService.h
>>> - new RenderFromMetaTile signature commented out, should it be removed?
>>> ConfigProperties.cpp
>>> ConfigProperties.h
>>> - TileServicePropertyUseMetaTile**s, TileServicePropertyLockMethod
>>> should be doc'd in RFC.
>>> - New properties should be added to MgConfigProperties::sm_**cviTileServiceProperties
>>> array
>> DONE
>>> AGGRenderer.cpp
>>> - "META" image format could be defined in MgImageFormats as an
>>> INTERNAL_API
>>> - new ::SaveMethod uses format = "META". I am not 100% clear on how this
>>> all fits together. Some algorithm documetation in the RFC would be helpful.
>>> - Can assert be replaced by a throw (MgInvalidArgumentException)?
>> added imageformat and mimetype for this
>>> AggImageIO.cpp
>>> - Please remove commented out code.
>>> ServerRenderingService.vcproj
>>> - Rendering Service should not depend on Tile service headers.
>> I know, but I needed these dependencies due to the way the metatile is
>> being passed around. As mentioned above I would appreciate a brief
>> discussion regarding a different approach.
>>> ServerRenderingService.cpp
>>> - GetTileCoords()
>>> What purpose does tileColOffset serve?
>>> Could this method be moved into MgMap as an INTERNAL_API method which
>>> takes tileWidth and tileHeight as parameters?
>> moved to MgMap
>> - RenderTileFromMetaTile()
>>> Can asserts be replaced by MgInvalidArgumentException,
>>> MgOutOfRangeException?
>>> Should bsimp->GetLength() be tested for 0< size< 2^31 before casting?
>>> Why is MyByteSource required? The direct cast is fragile.
>> I am open for suggestions how to do it differently!
>> I tried to avoid touching Foundation classes, but those are not really
>> made for this so I had to use a cast.
>> I was juggling quite a bit with parameters and types to find the least
>> intrusive way to pass the metatile bitmap back from the RenderingService
>> back to the TileService to be placed into the separate subtiles.
>> ServerTileService.cpp
>>> - RFC documentation for sm_creationCutoffTime, sm_pollingInterval,
>>> sm_useMetaTiles, sm_lockMethod
>> OK coming up
>>> - sm_creationCutoffTime and sm_pollingInterval should use same time base.
>> ok, but specifying cutofftime as 120000 seems also impractical.
>>> - MgServerTileService::**MgServerTileService() : MgTileService()
>>> METAMAXDIM should be moved to configuration parameters
>>> MG_CONFIG_MAX_METATILE_DIM
>>> Error message should use MgConfigurationPropertyValueIs**OutOfRange
>>> <sstream> use could be dropped.
>> normal strings are typedef wstring STRING;
>> This is debug code which IMHO should not clutter the important logic, so
>> I chose the shortest way to code such a concatenation of values
>> by using std::wstringstream. I can add a macro to FoundationDefs.h next
>> to STRING if thats better.
>> Is there any other way to do a less verbose string concatenation?
> added config variables
>> - DetectLockFile()
>>> This functionality should be moved into MgTileCache and probably renamed
>>> to WaitForTileLock.
>>> Is a subsecond sleep really necessary?
>> As a performing tuning measure I figured it would have some impact to
>> have more fine grained control. Thinking about multicore systems> 4
>> cores this could speed up things significantly for small tiles. But I am
>> not insisting on this and personally more into the ACE::Conditions.
>>> ACE_OS::sleep (const ACE_Time_Value&tv) may simplify code
>> thats whats used on line 144
>>> - GetTile()
>>> Since there is no signature change to the public API, APIVERSION 1.2 is
>>> not really required.
>> I added those comments to understand the sparsely documented code
>> better. If its wrong I can remove it. Otherwise its documentation.
>>> - GetSingleTile()
>>> MgFoundBlockingLockFile must be added to resource string file(s) in
>>> MapGuideCommon/Resources
>> done
>>> - GetMetaTile()
>>> Locking methods should be documented in the RFC.
>>> Algorithm can be simplified by only generating a lock for the left top
>>> corner. Meta tiling will be always on or always off. For future work, each
>>> map will also be meta tiled or not.
>>> I believe there is too much special case locking logic coded here. The
>>> locking logic should be moved into MgTileCache (LockTile(), UnlockTile(),
>>> WaitForTileLock()).
>>> All error messages must be defined in MapGuideCommon/Resources
>> added some text to Trac rfc90 page
>>> TileCache.h
>>> - GetLockMap()
>>> Lock map structure should not be directly exposed using GetLockMap().
>>> LockTile() and UnlockTile() methods should be added. New methods should
>>> hide sm_lockMethod details from the rest of the code.
>> I gonna have a look at this refactoring.
> ______________________________**_________________
> mapguide-internals mailing list
> mapguide-internals at lists.**osgeo.org <mapguide-internals at lists.osgeo.org>
> http://lists.osgeo.org/**mailman/listinfo/mapguide-**internals<http://lists.osgeo.org/mailman/listinfo/mapguide-internals>
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
