[mapguide-internals] Initial review on RFC90 - Need help with repo actions
UV uvwild at googlemail.com
Fri Jun 3 12:07:26 EDT 2011
Hello MG internal team,
I would like to finalize the rfc90 submission.
However, my code changes are ridiculously small compared to the trunk
changes since I started with rfc90.
As well I recently failed to remotely merge the trunk back into the
rfc90 feature branch (probably due to resource limitations)
Please, could someone sitting close to the repository either
a) delete rfc90 branch and create a new branch from trunk
b) or create a new branch called e.g. metatiling from trunk
and provide access to them for me?
The generaly functionality of the rfc90 contribution is basicallly
finished since a year.
But the simple refactoring of the code to fulfill the reviewers requests
turned into 95% merge and setup and 5% writing code. (including many
long hours of repo actions) due to the long breaks I had to take.
So to finish this with minimal effort I would like to locally merge my
few changes into a new branch which then can be hopefully reviewed
quickly and merged back into the trunk. This should cut down the work
considerably.  Alternatively I create a patch for trunk, however, such a
patch against trunk is also a moving target and therefore not the best
solution.
Thank you for your support.
More information about the mapguide-internals mailing list
