[mapguide-internals] Re: Help Please! - debug build of trunk fails in webtier with wrong request->handler SOLVED
UV uvwild at googlemail.com
Wed Jun 22 08:52:52 EDT 2011
I finally got it working.
There was some manual fixing of httpd.conf and php.ini necessary to get
a debug build up and running.
There is a problem with alternating installs of release and debug versions
(probably due to name clashs between the 2 versions of libs/modules with
the same name??)
Installing a debuggable server used to be a lot more straightforward and
robust in earlier releases
(maybe cause of the new php 5.3?) and due to the naming conflicts this
is quite obscure now.
More information about the mapguide-internals mailing list
