[mapguide-internals] MGOS 2.1 Failed Install Notes
Minh Vo
mvo at marmak.ca
Tue Mar 22 09:33:11 EDT 2011
Zac,
I have implemented the 'php_MapGuideApiEnvConfig.dll' procedure but it didn't work for me. However, I found that it was a security issue relating to permission access to write to the temp folder in the Windows directory for MG 2.0.2. After adding the machine to a domain, I added the machine's IUSR & IWAM to the folder with write permission and it worked.
mguser
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Monday, March 21, 2011 9:12 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] MGOS 2.1 Failed Install Notes
did you try the solution as described provided?
please respond to the mapguide-users list rather than mapguide-internals
z
On Tue, Mar 22, 2011 at 6:41 AM, @mguser <mvo at marmak.ca> wrote:
> Hi,
> I'm using MapGuide 2.0.2 on XP SP3 and I'm encountering the same problem.
> Has there been a solution to this problem?
> Thanks.
> http://osgeo-org.1803224.n2.nabble.com/MGOS-2-1-Failed-Install-Notes-t
> p2605463p6193674.html Sent from the MapGuide Internals mailing list
> archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
