[mapguide-internals] Release Readiness doc?
Martin Morrison
martin.morrison at edsi.com
Thu May 5 08:01:12 EDT 2011
Zac,
Do you really want me to start a ticket when I haven't researched it and asked the list? At the time I didn't have the extra time to mess with anything other than getting a quick fix. I do now.
If I get a decent fix, I will submit it. I did not consider the last one decent.
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA 24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Wednesday, May 04, 2011 10:25 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Release Readiness doc?
How come I can't find a bug in trac about this, if the problem dates
back to 2.1?
Of course we want to fix regressions, but if people don't bother to
report bugs in trac, things get missed
If you have a messy hack which fixed it, it should of been attached to
a ticket as a diff and a review requested
On Thu, May 5, 2011 at 2:47 AM, Martin Morrison
<martin.morrison at edsi.com> wrote:
> I understand the moving browser...that is the biggest reason for us to push to get the new version out the door. This fails across all browsers...multiple version too.
> A little history. In 2.02 hyperlinks worked. You could place html anchor tags in the data and they displayed as hyperlinks in the properties window. In 2.1 this was broken. However we figured out a messy hack (see below) that would re-enable them. This hack worked in 2.2 RC2.
> Fast forward to 2.2 release. The 2.1 hack does not work. I see the anchor tags in the properties window, not the links. There was a reference to this issue in this thread... http://osgeo-org.1803224.n2.nabble.com/Hyperlinks-in-Properties-pane-of-Ajax-viewer-td5480165.html When I look at what is coming to the browser in Firebug I see escaped data, e.g. < rather than <.
> I looked through the changes at this link:
> http://trac.osgeo.org/mapguide/changeset?old_path=%2Fbranches%2F2.2%2FMgDev&old=5354&new_path=%2Fbranches%2F2.2%2FMgDev&new=5739
> I'm not a skilled C(whatever) programmer, but I don't see anything that would have broken this. So the question is: What has changed that broke this? How do we fix it? It is NOT an option to lose this functionality.
> *********************************hack*******************************
> In \viewerfiles\propertyctrl.templ
> Add this function under
> // private functions -----------------------------------------------
> function htmlDecode(input) {
> var e = document.createElement('div');
> e.innerHTML = input;
> return e.childNodes[0].nodeValue;
> In function SetProperties – change the lines highlighted below as follows:
> SetProperties(count, properties)
> // code = '<table id="Grid" cellspacing=0 cellpadding=0 border=0><tr class="Header"><td id="Name" class="Name" width=65><span style="font-family: __#@font#__; font-size: __#@fontsize#__;"> __#PROPERTIESNAME#__</span></td><td class="CellSplitter" width=1 onmousedown="StartResizing()"></td><td class="Value"><span style="font-family: __#@font#__; font-size: __#@fontsize#__;"> __#PROPERTIESVALUE#__</span></td></tr>';
> // for(var i=0; i < properties.length; i++)
> // code += '<tr class="GridCell"><td><span style="font-family: __#@font#__; font-size: __#@fontsize#__;"> ' + properties[i].name + '</span></td><td></td><td><span style="font-family: __#@font#__; font-size: __#@fontsize#__;">' + properties[i].value + '</span></td></tr>';
> // code += '</table>';
> // GetMapFrame().SetPropertyPaneToolbarVisibility(true);
> // EDSI CHANGE START
> for(var i=0; i < properties.length; i++) {
> var EDSIText;
> var EDSIpattern = /^\</;
> if (EDSIpattern.test(properties[i].value)) {
> EDSIText = htmlDecode(properties[i].value);
> } else {
> EDSIText = properties[i].value;
> code += '<tr class="GridCell"><td><span style="font-family: __#@font#__; font-size: __#@fontsize#__;"> ' + properties[i].name + '</span></td><td></td><td><span style="font-family: __#@font#__; font-size: __#@fontsize#__;">' + EDSIText + '</span></td></tr>';
> code += '</table>';
> // EDSI CHANGE END
> *********************************end********************************
> Martin Morrison
> Roanoke, VA 24018
> 540.345.1410
> gis.edsi.com
> Sent: Wednesday, May 04, 2011 10:44 AM
> exact records: http://trac.osgeo.org/mapguide/browser/branches/2.2/MgDev
> nothing has changed in the ajax viewer in 6 months, but browsers are a
> moving target
> On Thu, May 5, 2011 at 12:12 AM, Martin Morrison
>> Where is a document for the official release of 2.2 similar to this?
>> http://trac.osgeo.org/mapguide/wiki/ReleaseReadiness22RC2
>> I'm trying to fix an issue that appeared between 2.2 RC2 and the 2.2 release with HTML links in the data. (AJAX viewer, windows server) It would be helpful to know exactly what was supposed to have changed.
>> Martin Morrison
>> Roanoke, VA 24018
>> 540.345.1410
>> gis.edsi.com
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer
+61 405 847 168
More information about the mapguide-internals
