[mapguide-internals] Re: The name of the current function is (null)
Jackie Ng
jumpinjackie at gmail.com
Tue May 31 12:44:36 EDT 2011
I'm thinking it's some Apache module or PHP extension that is probably
required by this library but is not loaded by default on the
mapguide-bundled Apache/PHP.
You should diff the httpd.conf and php.ini files of your MapGuide and WAMP
installs to see what differences there are.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/The-name-of-the-current-function-is-null-tp6423442p6423560.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
