[mapguide-internals] Mapguide roadmap
Jason Birch
jason at jasonbirch.com
Tue May 31 19:14:55 EDT 2011
This is something that can be configured at the webserver level for
both IIS and Apache. I think I saw Jackie check in the necessary
changes for Apache.
IMO for IIS this should be up to the site admin to set up as a config
best practice (along with setting up long caching for images/css/js)
unless someone is brave enough to step up and figure out what to do
about the complexity of enabling/installing modules, adding compressed
content types, etc on IIS via scripting. Apache is "easy" because we
control the entire install. IIS is a pain in the ass because of the
number of potential configuration states.
Jason
On 2011-05-31, Martin Morrison <martin.morrison at edsi.com> wrote:
> On the gzip ticket (#1652), everything possible should be compressed before
> sending over the wire...
> Martin Morrison
> Application Engineer
> Engineering Design Systems, Inc.
> 3780 Peters Creek Rd Ext SW
> Roanoke, VA 24018
> 540.345.1410
> gis.edsi.com
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac
> Spitzer
> Sent: Monday, May 30, 2011 1:37 AM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] Mapguide roadmap
> Two performance improvement I'd like to see in 2.2.1
> http://trac.osgeo.org/mapguide/ticket/1652 (gzip for mapagent)
> Studio requests the describe schema xml multiple times and for
> a larger schema it be can up over 1.5mb in size
> http://trac.osgeo.org/mapguide/ticket/462 (GDAL connection opening
> improvements, 10x win)
> Two bug fixes which I'd like to nominate are
> http://trac.osgeo.org/mapguide/ticket/1705 (truncated large WFS responses
> and memory leak)
> http://trac.osgeo.org/mapguide/ticket/1705 (webserver crash on parsing
> invalid characters in numeric params)
> On Sat, May 28, 2011 at 3:40 AM, Martin Morrison
> <martin.morrison at edsi.com>wrote:
>> Needs to be in 2.2.1
>> http://trac.osgeo.org/mapguide/ticket/1682
>> Martin Morrison
>> Roanoke, VA 24018
>> 540.345.1410
>> gis.edsi.com
>> <stuff deleted>
>> What would you like fixed in MapGuide 2.2.1?
>> <more stuff deleted>
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
More information about the mapguide-internals
