[mapguide-internals] Please review the patch for ticket #1850
Zac Spitzer
zac.spitzer at gmail.com
Tue Nov 15 22:15:09 EST 2011
the patch file is corrupt? looks like it's a zip file?
On Wed, Nov 16, 2011 at 2:10 PM, Bruce Li <bruce.li at autodesk.com> wrote:
> Hi lists,
> I add a new patch "fix Ticket #1850.patch" for you review in http://trac.osgeo.org/mapguide/ticket/1850.
> This patch fixed the issue: if you open a tab of map preview and minimize the studio window, an unexpected pop message will appear.
> Solution:
> The minimizing of studio will trigger the function of OnresizeChanged which will send a map request with an invalid parameter,
> this patch add a check of parameter before sending map request. If the parameter is invalid, the map request will not be sent.
> Please review. Thanks.
> Bruce Li
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
