[mapguide-internals] IPv6 support mandatory?
Mars Wu
mars.wu at autodesk.com
Mon Sep 12 23:00:05 EDT 2011
Hi Jackie,
IPv6 should not be mandatory. Do you know what the address is when this error happens? It's IPv4 or IPv6?
Thanks,
Mars
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Monday, September 12, 2011 1:30 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] IPv6 support mandatory?
Hi All,
Does MapGuide now *require* an IPv6-enabled connection in order to run?
I did a installation of trunk to a Windows 2003 Server box, and the server wouldn't start up due to "unsupported address family" error in ACE_Select_Reactor_T::open
Once I added IPv6 support, the server ran without problems.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/IPv6-support-mandatory-tp6782335p6782335.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
