[mapguide-internals] RE: IPv6 support mandatory?
Mars Wu mars.wu at autodesk.com
Mon Sep 12 23:12:13 EDT 2011
Hi Jackie,
Then that's a little bit strange. I have to debug to see what's the problem. I will let you know the result.
Thanks,
Mars
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Tuesday, September 13, 2011 11:11 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] RE: IPv6 support mandatory?
Hi Mars,
The IP address that I had in the serverconfig.ini was just the IPv4 loopback (ie. 127.0.0.1).
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/IPv6-support-mandatory-tp6782335p6786045.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
