[mapguide-internals] Additional legend enhancements
Trevor Wekel trevor_wekel at otxsystems.com
Thu Sep 29 19:08:27 EDT 2011
Hi Jackie, Hi List,
I was checking out Jackie's latest set of legend performance enhancements http://trac.osgeo.org/fusion/changeset/2428.  Very nice!
Since the legend images hit the full rendering stack, would it make sense to cache the images (maybe as javascript Data URIs) in the  resource data associated with the layer definition?
We could also craft up an HTTP call to return the full set of legend images for a layer with one HTTP request using the Data URI's.  Seems as though most browsers support it with the exception of IE6 and IE7.  I'm not sure if there are any other limitations to this approach.  Perhaps Jackie has more insight.
And if the map definition and layer definitions do not change, we could even cache the entire HTTP/Data URI response as resource data associated with the map definition.  I suppose the Data URI response could grow to over a megabyte if there were 1000+ legend images to return (16pix x 16pix x RGBA = 1k per image).  At least there would be 999 less HTTP and render calls.
Anyone like this idea?  I have a client who may be interested in pursuing some legend performance improvements for the AJAX viewer.  Common infrastructure for legend caching Data URI's could be used by both viewers.
Regards,
Trevor
More information about the mapguide-internals mailing list
