[mapguide-internals] RFC 122 - Configurable CS Dictionary Paths
Hugues Wisniewski hugues.wisniewski at autodesk.com
Fri Sep 30 10:47:01 EDT 2011
Hi Jackie,
It's great that you try to address this issue that's been going on for several years.
I'd like to get more detail about the proposed code change
I suspect you want to modify the implementation of STRING CCoordinateSystemCatalog::GetDefaultDictionaryDir()
In the RFC you mention "1.Read in the dictionary path from serverconfig.ini and webconfig.ini"
What exactly would be responsible for that?
CCoordinateSystemCatalog? Or it would be taken care of outside the MgCoordinateSystemxxx API?
CCoordinateSystemCatalog::GetDefaultDictionaryDir() is called by
CCoordinateSystemCatalog::SetDefaultDictionaryDirAndFileNames() which is called when the coordinate system catalog is being constructed in
CCoordinateSystemCatalog::CCoordinateSystemCatalog()
The catalog is a static member of the MgCoordinateSystemFactory initialized the first time someone needs the factory.
Before that, the catalog is never created and the dictionary path is never set.
It is set the first time the code encounters something like:
MgCoordinateSystemFactory factory; //here we create the factory
MgCoordinateSystem* pCs=Factory.CreateFromCode("LL84");
The MgCoordinateSystem set of APIs is not supposed to not know anything about serverconfig.ini and webconfig.ini so I'm curious to know more about the logic that would replace the current one.
Thanks a lot
Hugues
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Friday, September 30, 2011 12:58 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] RFC 122 - Configurable CS Dictionary Paths
Hi All,
I have posted a new RFC which addresses one of my major annoyances: Removing
the dependency on MENTOR_DICTIONARY_PATH
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc122
Please review
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/RFC-122-Configurable-CS-Dictionary-Paths-tp6847435p6847435.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
