[mapguide-internals] Selection problem with Oracle 10g
Zac Spitzer zac.spitzer at gmail.com
Wed Apr 18 01:26:36 EDT 2012
are you sure the projections (srid) are set correctly for both the geometries
and the user sdo_geom_metadata?
selection will fail if the query window is in the wrong cs
On Wed, Apr 18, 2012 at 4:24 PM,  <berit.schaefer at gmx.de> wrote:
> yes, otherwise it would not work at all, because I'm working with the topobase structure. I can't create  a object without a primary key...
> Zac Spitzer <zac.spitzer at gmail.com> hat geschrieben:
>>does your table have a primary key?
>>On Wed, Apr 18, 2012 at 2:54 AM,  <Berit.Schaefer at gmx.de> wrote:
>>> Hi,
>>> i'm trying to use oracle spatial 10g with MGOS(Release 2.1.0). I'm using
>>> Kingoracle provider. The features show up just fine but I can't select them.
>>> Selecting shape objects works fine.
>>> The FDO Provider is the version  King.Oracle.3.4.
>>> I've read that there are quite a lot user which have this problem, but I
>>> could find it solved.
>>> Hope somebody can help me solve this problem.
>>> Thanks
>>> mapguide-internals mailing list
>>> mapguide-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>>Zac Spitzer
>>Solution Architect / Director
>>Ennoble Consultancy Australia
>>http://www.ennoble.com.au
>>http://zacster.blogspot.com
>>+61 405 847 168
Zac Spitzer
+61 405 847 168
More information about the mapguide-internals mailing list
