[mapguide-internals] Motion: Vote MapGuide RFC 125 - Support Google Street View in Fusion
Jason Birch
jason at jasonbirch.com
Mon Aug 27 11:38:28 PDT 2012
This functionality has a strong likelihood to be in violation of the Google
Maps API T&C in many cases, at least without an Enterprise agreement:
http://googlegeodevelopers.blogspot.ca/2012/04/update-to-google-maps-api-deprecation.html
"There are certain Maps API Services, such as Places and Street View, which
you are permitted to use without a Google Map. This update clarifies that
if you do choose to use a map with these services it must be a Google Map."
Is the widget going to be smart enough to disable itself when not used with
a Google base map?
Jason
On 22 August 2012 08:37, Bruce Dechant <bruce.dechant at autodesk.com> wrote:
> Hi All,
> With the review finished I motion for a vote on:
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc125
> +1 Bruce
> Thanks,
> Bruce
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
