[mapguide-internals] Re: Upgrade to VC10 and GDAL 1.9
    Trevor Wekel
    trevor_wekel at otxsystems.com
    Sat Feb  4 00:10:39 EST 2012
Hi Jackie,
I wonder what would happen if we didn't release 32 bit on Windows?
[oh oh.. here comes the flame war]
For the GDAL 1.9 upgrade, I have posted a partial binary drop of MapGuide 2.4 64bit.  It was built from the same machine that produced the 2.2 builds.  The build process still needed some baby-sitting.  It's getting closer.
The zip is just a bunch of files so IIS will have to be configured manually.  The readme in the zip contains a few hints.  If the zip is extracted to C:\mg24x64, all of the directory references should work.  It's definitely an EARLY build.  It may be ok for development work.
If anyone has any concerns with the GDAL 1.9 upgrade, please try it out.  I think the FDO PSC will need a stamp of approval from the MapGuide PSC before we do the GDAL upgrade.
The drop contains:
64bit MapGuide Server for Windows
64bit PHP and .Net Web Extensions for IIS
64bit GDAL, WMS, OGR, SDF, SHP, ODBC, SQLite, and SQLServerSpatial FDO providers
http://download.osgeo.org/mapguide/testing/2.4.0/mg24x64test1.zip
The file size should be 223,608,232 bytes and the md5sum is b313f6280a0158d616b717a9d64abb0c.
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: February 2, 2012 11:25 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Re: Upgrade to VC10 and GDAL 1.9
Hi Trevor,
The installer has already been updated to use and configure PHP to use
FastCGI for IIS.
That httPHPdSSL distribution would've been ideal if it:
 - Also had the 32-bit build (which I couldn't find anywhere)
 - Apache and PHP weren't mixed together in the same directory (ugh!)
because we want to use the same PHP for both Apache and IIS configurations.
Anyway, I'm gonna keep trucking along (gonna try with a slightly older
libiconv which has working msvc makefiles)
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Upgrade-to-VC10-and-GDAL-1-9-tp4337041p4360859.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
