[mapguide-internals] Re: Upgrade to VC10 and GDAL 1.9
Trevor Wekel trevor_wekel at otxsystems.com
Wed Feb 8 17:09:26 EST 2012
Hi Jackie,
You are correct, side by side is not 100% working due to the same ports being used in serverconfig.ini and webconfig.ini
I removed most of the SVN directories from the web tier directories and just kept the Fusion SVN directories.  I wasn't sure what we were keeping and what we were not.
The PHP build is the same one I referenced from Apache Lounge.
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: February 7, 2012 8:59 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Re: Upgrade to VC10 and GDAL 1.9
Hi Trevor,
I gave this 64-bit build for a spin. Sheboygan loads up fine. There was some
mapagent communication issues, which I'm guessing is due to an existing
IIS-configured installation of MGOS 2.2 on my machine. Yeah, not an ideal
test environment, but if anything this tells me what needs to be done to
better support side-by-side IIS configured installations.
Is the build machine using SVN 1.6 and the latest build scripts from trunk?
Because apart from fusion, I don't see any of the svn metadata being
preserved in the web tier directories. The trunk build scripts preserve this
metadata.
Also is the PHP in this build the same as the one you referenced from
apachelounge? I've checked in this version (with the httpd binaries ripped
out) for the installer.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Upgrade-to-VC10-and-GDAL-1-9-tp4337041p4374819.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
