[mapguide-internals] MapGuide RFC 124 is ready for reveiw
Ted Yang
ted.yang at autodesk.com
Mon Jul 9 19:38:17 PDT 2012
Hi Zac,
Thanks for the question. I am not familiar with GDAL + Geospatial PDF, but after taking a quick look at the link, it seems it is all related with using Geospatial PDF as feature source of GDAL, or using GDAL to render raster files to be PDF, which is not really the same thing we are thinking about for the Quick Plot enhancement.
The enhancement that RFC 124 is proposing is to leverage the Adobe Reader's powerful plot control functionalities to ensure we could get "precise" printed map copy in a browser (with Fusion viewer). TCPDF is a PDF creation library and has great control for the generated PDF layout. TCPDF can add image, text, lines and so on easily to the PDF document with precisely control. Also TCPD is based on PHP, which could be easily used in Fusion. Then the user could print the map through Adobe Reader to get a "precise" copy. Most browsers support Adobe Reader add-in which means the user doesn't have to launch Adobe Reader manually, the document will be just printed in browser.
Best wishes,
Ted
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Wednesday, July 04, 2012 12:14 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] MapGuide RFC 124 is ready for reveiw
how does TCPDF compare to http://www.gdal.org/frmt_pdf.html?
On Wed, Jul 4, 2012 at 1:08 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Probably out of scope, but would it be possible to leverage the
> existing Print Layout resource type when plotting to PDF?
> - Jackie
> http://osgeo-org.1560.n6.nabble.com/MapGuide-RFC-124-is-ready-for-reve
> iw-tp4983862p4985836.html Sent from the MapGuide Internals mailing
> list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
