[mapguide-internals] Re: FreeBSD/OSX Port - FDO Version?
Craig Miller
craig.miller at spatialminds.com
Mon May 7 22:51:04 EDT 2012
Thanks Jackie. I'll give creating and FDO BSD Ports "Portfile" a go. It'll be interesting to see where it leads as BSD ports is very modular compared to the default setup in the FDO build scripts.
Thanks,
Craig
Craig Miller
http://spatialminds.com
On May 7, 2012, at 6:59 PM, Jackie Ng wrote:
> Each version of MapGuide works against a particular version of FDO, and yes
> this is a hard requirement.
> If you want a FreeBSD/OSX port going, I'd suggest working against MapGuide
> 2.4/FDO 3.7 instead. This way you won't have such a big moving target.
> - Jackie
> View this message in context: http://osgeo-org.1560.n6.nabble.com/FreeBSD-OSX-Port-FDO-Version-tp4959085p4959295.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
