[mapguide-internals] Motion: Vote MapGuide RFC 125 - Support Google Street View in Fusion
Ted Yang ted.yang at autodesk.com
Mon Sep 3 03:02:29 PDT 2012
Hi Jason,
Thanks for the reminder, we will disable it when the Google base map is not in use.
Best wishes,
Ted
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Tuesday, August 28, 2012 2:38 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Motion: Vote MapGuide RFC 125 - Support Google Street View in Fusion
This functionality has a strong likelihood to be in violation of the Google Maps API T&C in many cases, at least without an Enterprise agreement:
http://googlegeodevelopers.blogspot.ca/2012/04/update-to-google-maps-api-deprecation.html
"There are certain Maps API Services, such as Places and Street View, which you are permitted to use without a Google Map. This update clarifies that if you do choose to use a map with these services it must be a Google Map."
Is the widget going to be smart enough to disable itself when not used with a Google base map?
Jason
On 22 August 2012 08:37, Bruce Dechant <bruce.dechant at autodesk.com> wrote:
> Hi All,
> With the review finished I motion for a vote on:
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc125
> +1 Bruce
> Thanks,
> Bruce
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
