[mapguide-internals] Permanently drop the ArcSDE provider?
Trevor Wekel
trevor_wekel at otxsystems.com
Mon Sep 24 15:58:56 PDT 2012
I did a quick check on the ESRI website and it looks as though access to the required SDK is through the Esri Developer Network (EDN) program. The last time I checked, an EDN subscription cost somewhere around $3000 USD per year.
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: September 24, 2012 3:13 AM
To: mapguide-internals at lists.osgeo.org
Subject: Re: [mapguide-internals] Permanently drop the ArcSDE provider?
You've hit the crux of the problem.
Those that can build the full MapGuide/FDO stack (who are not Autodesk) do not have access to the non-free ESRI SDK. How could GeoServer put out releases with ArcSDE support? Obviously someone in their build team must have a production/developer licence of ArcSDE in order to build such support.
We (who are not Autodesk) have no such people.
Unless you are raising your hand? :)
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Permanently-drop-the-ArcSDE-provider-tp5002828p5003939.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
