[mapguide-internals] Blocking issue in Mapguide 2.4
Zac Spitzer zac.spitzer at gmail.com
Sun Feb 17 23:19:08 PST 2013
either of these two?
http://trac.osgeo.org/mapguide/ticket/2165
http://trac.osgeo.org/mapguide/ticket/649
On Mon, Feb 18, 2013 at 6:16 PM, Bruno Scott <bscott at geomapgis.com> wrote:
> Don't understand why i just discover that one now.
> Using Mapguide Server API featureService.UpdateFeatures(...)
> if the database returns an error ( lets say a constraint violation for
> example )
> further database access using Mapguide API fails. (Need to restart the
> server to repair)
> I've tried to isolate the problem
> It's not provider specific( i reproduce the bug with King.Oracle,
> Autodesk.Oracle, OSGeo.Sqlite)
> it does not seem to be FDO related ( no problem doing the same thing with
> FdoToolbox)
> So it really likely to be Mapguide 2.4 related. Mapguide 2.2 works OK.
> Something is going wrong catching FDO errors in Mapguide 2.4.
> I'm now trying to figure out what's going on while in debug mode.
> Not easy,
> Does anyone has worked on catching Fdo errors since 2.2?
> Some Clue would be appreciated.
> Bruno Scott
> http://osgeo-org.1560.n6.nabble.com/Blocking-issue-in-Mapguide-2-4-tp5034831.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
More information about the mapguide-internals mailing list
