[mapguide-internals] Motion: RFC129 - SWIG/IMake enhancements and enhanced Java wrapper API
Haris Kurtagic haris at sl-king.com
Fri Jan 11 05:13:35 PST 2013
+1
Haris
On Fri, Jan 11, 2013 at 5:08 AM, Trevor Wekel
<trevor_wekel at otxsystems.com>wrote:
> Hi Jackie,
> +1 Trevor
> The modification to the build and documentation process will likely cause
> some work for Autodesk.  I think their build scripts are quite different.
> Switching to lower camel case for method names is more in line with Java
> standards.  It is good that the old wrapper is being supported for the time
> being since the name change will break all existing apps based on the Java
> API.  Both APIs will have to be maintained for a release or two if the
> decision is made to drop the old API wrapper.
> Regards,
> Trevor
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:
> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: January 9, 2013 9:30 PM
> To: mapguide-internals at lists.osgeo.org
> Subject: [mapguide-internals] Motion: RFC129 - SWIG/IMake enhancements and
> Hi All,
> I motion for a vote on
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc129
> +1 Jackie
> http://osgeo-org.1560.n6.nabble.com/Motion-RFC129-SWIG-IMake-enhancements-and-enhanced-Java-wrapper-API-tp5026528.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
