[mapguide-internals] RFC 135: Support Visual Studio 2012
Haris Kurtagic haris at sl-king.com
Sat Jun 1 15:33:44 PDT 2013
Hi Andy,
Sorry for late response, I was a offline for couple of days.
It would be great if initially it would build in previous VS compiler
versions too. I guess we could get benefits of moving  to use new Studio
and still doesn't need to do immediately support new compiler versions.
I believe one small thing, but important when comes to using solution and
project, is to setup such configuration properties for directories
(Output,Bin, Lib ..) so it includes platform toolset so it would be able to
support different compiler builds
Haris
On Fri, May 31, 2013 at 7:06 AM, Andy Zhang <Andy.Zhang at autodesk.com> wrote:
> Hi Haris,
> >>>>We could use "Platfrom Toolset" project configuration option to
> achieve that.
> Could you please provide more detail about this? In my VS2012, we can
> select several platform toolsets including VS2010(v100), VS2012(v110) in
> project properties page. Do you mean we need to make the projects built
> successfully when we select VS2010(v100)?
> Thanks
> Andy
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:
> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
> Sent: Friday, May 31, 2013 6:42 AM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] RFC 135: Support Visual Studio 2012
> Hi,
> is it possible that even if we move to 2012 project/solution files,  we
> keep configurations for 2010 ? We could use "Platfrom Toolset" project
> configuration option to achieve that.
> I am currently using this approach for my FDO builds, where I need to
> build different versions of libs. Having different project files for
> different studio builds is huge overhead.
> I am also extensively using property sheets, for easy customization of the
> configuration builds.
> Haris
> On Thu, May 30, 2013 at 2:50 PM, Mars Wu <mars.wu at autodesk.com> wrote:
> > Previously, we did the upgrades (for PHP etc.) in a separate RFC. It
> > happened that php binaries in MapGuide are built from different
> > version of VC. It seems there is no cross-dll memory allocation and
> > release so it should be safe to leave PHP built with VC10 and just
> > upgrade MapGuide to
> > VS12 first.
> > Thanks,
> > Mars
> > mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> > Sent: Thursday, May 30, 2013 10:22 AM
> > To: mapguide-internals at lists.osgeo.org
> > Just occurred to me. I believe the binaries we're keeping under
> > Oem\php\Release_TS and Oem\php\x64\Release_TS are VS2010 built ones.
> > Will we require VS2012 built copies of Apache and PHP as well as part
> > of this RFC?
> > - Jackie
> > View this message in context:
> > http://osgeo-org.1560.x6.nabble.com/RFC-135-Support-Visual-Studio-2012
> > -tp5053832p5056855.html Sent from the MapGuide Internals mailing list
> > archive at Nabble.com.
> > mapguide-internals mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
