[mapguide-internals] RFC 135: Support Visual Studio 2012
Haris Kurtagic
haris at sl-king.com
Mon Jun 3 03:00:57 PDT 2013
Hi Andy,
thanks for adding to RFC. I am not sure from the text in RFC, it would be
good to have in project properties for output, intermediate and lib
directory to include $(PlatformToolset) macro
so insetad of (MG 2.2 ) ..\..\obj\release64\ServerCore to have like
..\..\obj\$(PlatformToolset)\release64\ServerCore
btw, personally i would also like to have instead of release configuration
macro etc..
Haris
On Mon, Jun 3, 2013 at 8:41 AM, Andy Zhang <Andy.Zhang at autodesk.com> wrote:
> Hi Haris,
> Thanks for your reply.
> I updated the RFC to add the line below.
> * We will add configurations such as 'Release v100' and 'Debug v100' which
> use platform toolset v100 for those who need to build v100 versions of
> files.
> Are we ready for vote?
> Best Regards
> Andy
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:
> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
> Sent: Sunday, June 02, 2013 6:34 AM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] RFC 135: Support Visual Studio 2012
> Hi Andy,
> Sorry for late response, I was a offline for couple of days.
> It would be great if initially it would build in previous VS compiler
> versions too. I guess we could get benefits of moving to use new Studio
> and still doesn't need to do immediately support new compiler versions.
> I believe one small thing, but important when comes to using solution and
> project, is to setup such configuration properties for directories
> (Output,Bin, Lib ..) so it includes platform toolset so it would be able to
> support different compiler builds
> Haris
> On Fri, May 31, 2013 at 7:06 AM, Andy Zhang <Andy.Zhang at autodesk.com>
> wrote:
> > Hi Haris,
> > >>>>We could use "Platfrom Toolset" project configuration option to
> > achieve that.
> > Could you please provide more detail about this? In my VS2012, we can
> > select several platform toolsets including VS2010(v100), VS2012(v110)
> > in project properties page. Do you mean we need to make the projects
> > built successfully when we select VS2010(v100)?
> > Thanks
> > Andy
> > Kurtagic
> > Sent: Friday, May 31, 2013 6:42 AM
> > Hi,
> > is it possible that even if we move to 2012 project/solution files,
> > we keep configurations for 2010 ? We could use "Platfrom Toolset"
> > project configuration option to achieve that.
> > I am currently using this approach for my FDO builds, where I need to
> > build different versions of libs. Having different project files for
> > different studio builds is huge overhead.
> > I am also extensively using property sheets, for easy customization of
> > the configuration builds.
> > Haris
> > On Thu, May 30, 2013 at 2:50 PM, Mars Wu <mars.wu at autodesk.com> wrote:
> > > Previously, we did the upgrades (for PHP etc.) in a separate RFC. It
> > > happened that php binaries in MapGuide are built from different
> > > version of VC. It seems there is no cross-dll memory allocation and
> > > release so it should be safe to leave PHP built with VC10 and just
> > > upgrade MapGuide to
> > > VS12 first.
> > > Thanks,
> > > Mars
> > > mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> > > Sent: Thursday, May 30, 2013 10:22 AM
> > > To: mapguide-internals at lists.osgeo.org
> > > 2012
> > > Just occurred to me. I believe the binaries we're keeping under
> > > Oem\php\Release_TS and Oem\php\x64\Release_TS are VS2010 built ones.
> > > Will we require VS2012 built copies of Apache and PHP as well as
> > > part of this RFC?
> > > - Jackie
> > > View this message in context:
> > > http://osgeo-org.1560.x6.nabble.com/RFC-135-Support-Visual-Studio-20
> > > 12 -tp5053832p5056855.html Sent from the MapGuide Internals mailing
> > > list archive at Nabble.com.
> > > _______________________________________________
> > > mapguide-internals mailing list
> > > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
