[mapguide-internals] RFC 135: Support Visual Studio 2012
Haris Kurtagic
haris at sl-king.com
Thu May 30 15:41:45 PDT 2013
is it possible that even if we move to 2012 project/solution files, we
keep configurations for 2010 ? We could use "Platfrom Toolset" project
configuration option to achieve that.
I am currently using this approach for my FDO builds, where I need to build
different versions of libs. Having different project files for different
studio builds is huge overhead.
I am also extensively using property sheets, for easy customization of the
configuration builds.
Haris
On Thu, May 30, 2013 at 2:50 PM, Mars Wu <mars.wu at autodesk.com> wrote:
> Previously, we did the upgrades (for PHP etc.) in a separate RFC. It
> happened that php binaries in MapGuide are built from different version of
> VC. It seems there is no cross-dll memory allocation and release so it
> should be safe to leave PHP built with VC10 and just upgrade MapGuide to
> VS12 first.
> Thanks,
> Mars
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:
> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Thursday, May 30, 2013 10:22 AM
> To: mapguide-internals at lists.osgeo.org
> Subject: Re: [mapguide-internals] RFC 135: Support Visual Studio 2012
> Just occurred to me. I believe the binaries we're keeping under
> Oem\php\Release_TS and Oem\php\x64\Release_TS are VS2010 built ones.
> Will we require VS2012 built copies of Apache and PHP as well as part of
> this RFC?
> - Jackie
> http://osgeo-org.1560.x6.nabble.com/RFC-135-Support-Visual-Studio-2012-tp5053832p5056855.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
