[mapguide-internals] C1001 internal error when building Oem/lib_json in Release|x64
Jackie Ng
jumpinjackie at gmail.com
Wed Dec 9 03:03:16 PST 2015
Hi All,
Just a heads up, Oem/lib_json fails to build (at least on my machine) when
building it in Release|x64 configuration with Visual Studio 2015 Update 1.
The error output looks like this:
1>c:\program files (x86)\microsoft visual studio
14.0\vc\include\vector(1656): fatal error C1001: An internal error has
occurred in the compiler.
1> (compiler file 'f:\dd\vctools\compiler\utc\src\p2\main.c', line 246)
1> To work around this problem, try simplifying or changing the program
near the locations listed above.
1> Please choose the Technical Support command on the Visual C++
1> Help menu, or open the Technical Support help file for more information
1> link!InvokeCompilerPass()+0x2d4bd
1> link!DllGetC2Telemetry()+0xae663
All other configurations build fine.
I'm going to try building this on another machine just to see if it is not
isolated to this one particular machine.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/C1001-internal-error-when-building-Oem-lib-json-in-Release-x64-tp5240500.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
