[mapguide-internals] Patch for ticket 2538 (MgMap fails to initialize properly from linked tile set if both coordinate systems match)
Jackie Ng jumpinjackie at gmail.com
Wed Feb 18 07:06:22 PST 2015
Hi All,
Attached is a patch for ticket 2538
http://trac.osgeo.org/mapguide/ticket/2538
When we create a MgMap from a Map Definition that links to a tile set, if
both tile set and Map Definition have the same coordinate system, the
map/data extent and center do not actually get initialized, which causes
problems when we try to load such a map in the AJAX viewer that expects a
non-null map extent.
Please review. Thanks.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Patch-for-ticket-2538-MgMap-fails-to-initialize-properly-from-linked-tile-set-if-both-coordinate-sys-tp5188427.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
