[mapguide-internals] Review/Discuss: MapGuide RFC 149 (Lightweight MapGuide Source Tree)
Andy Zhang Andy.Zhang at autodesk.com
Thu May 28 20:57:57 PDT 2015
Hi Jackie,
Thanks for the reply.
I have another question, the Oem folder will be moved up on level. Will there be a folder like OemBranch corresponding to the MgDevBranch?
Thanks
Andy
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Friday, May 29, 2015 10:41 AM
To: mapguide-internals at lists.osgeo.org
Subject: Re: [mapguide-internals] Review/Discuss: MapGuide RFC 149 (Lightweight MapGuide Source Tree)
Hi Andy,
These OEM directories will stay inside MgDev:
 - agg
 - fusion
 - fusionMG
Everything else is moved out.
AGG has its source code files referenced directly by the Renderers project on Windows, so moving that directory out is impractical
fusion isn't so much an "external library" but a framework built on top of MapGuide that just happens to sit in an external repository, so there isn't much sense moving that out either.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Review-Discuss-MapGuide-RFC-149-Lightweight-MapGuide-Source-Tree-tp5207824p5208099.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
