[mapguide-internals] Broken Linux build post-VS2015 migration
Jackie Ng
jumpinjackie at gmail.com
Wed Oct 28 16:00:41 PDT 2015
Hi All,
I've been trying to build MapGuide on (Ubuntu) Linux after the VS2015
migration and have ran into several compiler errors:
Oem/DWFTK/develop/global/src/dwf/package/DefinedObject.cpp:
It's complaining about LONG_PTR being undefined. This seems to be a
windows-only typedef. What should be used on Linux (go back to long as it
was originally)?
Various files under Oem/geos:
It's complaining about std::fmax being undefined. This is a new function in
the C++11 standard library, should we be compiling all our code as C++11
(-std=c++11), or just #ifdef back in the original code for Linux?
There's probably others I've yet to encounter.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Broken-Linux-build-post-VS2015-migration-tp5233213.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
