[mapguide-internals] Please review RFC151: Add layer definition cache
Andy Zhang Andy.Zhang at autodesk.com
Mon Sep 21 00:40:06 PDT 2015
Hi Jackie,
Thanks for your feedback.
Currently, the internal object in the resource service cache is MdfModel::LayerDefinition object. It is got by method MgLayerBase::GetLayerDefinition(m_svcResource, layerid). I will update the code where calls MgLayerBase::GetLayerDefinition(m_svcResource, layerid) to use the cache. So both PreCacheMaps and MgResourceService.GetResourceContents() will NOT take advantage of the new cache now. We may add more internal objects to the resource service cache later.
Best Regards
Andy
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Monday, September 21, 2015 2:43 PM
To: mapguide-internals at lists.osgeo.org
Subject: Re: [mapguide-internals] Please review RFC151: Add layer definition cache
Hi Andy,
There is a PreCacheMaps property in serverconfig.ini that allows mgserver to pre-create a specified list of MgMap instances from the list of Map Definitions set.
With the introduction of the layer definition cache, does using PreCacheMaps allow us to pre-load this cache?
Similarly, does a call to MgResourceService.GetResourceContents() take advantage of this new layer definition cache if the list of resource ids includes layer definitions?
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Please-review-RFC151-Add-layer-definition-cache-tp5225108p5225118.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
