[mapguide-internals] MapGuide RFC 166 - Drop 32-bit builds for Windows
Martin Morrison martin.morrison at edsi.com
Fri Feb 9 18:58:10 PST 2018
We should remove the 32 bit build.  Anybody who is still running a 32 bit server is likely not into upgrading Mapguide as well.
So, my vote is +1
From: mapguide-internals <mapguide-internals-bounces at lists.osgeo.org> on behalf of Jackie Ng <jumpinjackie at gmail.com>
Sent: Friday, February 9, 2018 7:38 PM
To: mapguide-internals at lists.osgeo.org
Subject: Re: [mapguide-internals] MapGuide RFC 166 - Drop 32-bit builds for Windows
MapGuide data packages are platform-neutral.
- Jackie
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Internals-f4209935.html
OSGeo.org - MapGuide Internals | Mailing List Archive<http://osgeo-org.1560.x6.nabble.com/MapGuide-Internals-f4209935.html>
MapGuide Internals forum and mailing list archive. If you want your post to be seen by most subscribers, you MUST subscribe to the mailing lists using the above link. If you do not register, nobody...
mapguide-internals mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
