[mapguide-internals] MapGuide RFC 169 - Deprecate DWF-related functionality and services
Stephane Viviand sviviand at geomap-imagis.com
Mon Jan 14 00:40:55 PST 2019
Hi Jackie,
Does this RFC will remove support for displaying dwf fil in MapGuide as base
map layers ? this functionality is really used in our case to display base
map coming from drawing files
If so, I think there must be an alternative for MapGuide to support for
example georeferenced support pdf files. And hopefully with layer management
as we have with dwf file base.
If the only thing that it removes, is the ability to print as dwf files, we
actually agree to remove this.
Thanks for you answer.
Regards,
Stéphane
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Internals-f4209935.html
More information about the mapguide-internals mailing list
