[mapguide-internals] FDO Error
Jackie Ng
jumpinjackie at gmail.com
Mon Aug 16 07:14:00 PDT 2021
Sadly, MapGuide will not be divulging any additional context to help you
here.
All we have to go with is this warning is logged most of the time when
parsing a FDO expression during layer stylization.
What you can do is look at the timestamp of that error log entry and
cross-reference it against logged operations in Access.log around that same
time to see what operation could be triggering the error. It will most
likely be some operation that will be doing some form of stylization like
RenderMap, RenderDynamicOverlay or QueryMapFeatures.
>From there you should be able to isolate down to the offending map
definition and from there drill down to the layer containing the FDO
expression that is causing the problem.
Hope that helps.
- Jackie
You wrote:
I got a persistent error logging at Error.log. How can I track the problem ?
Mapguide 3.1.2 on a windows 2019 server.
<2021-08-14T15:24:56> 6048 Fusion Viewer 200.9.186.100
Anonymous
Warning: An exception occurred in FDO component.
Int32Value is null.
StackTrace:
- MgStylizationUtil.ExceptionTrap() line 166 file GeometryAdapter.cpp
Regards,
Liglio
*Please Note: I no longer create new posts or post replies to any OSGeo
mailing list through nabble. As a result, you most likely won't see this
message appear on nabble's view of any OSGeo mailing list and may only see
this message through mailing list archives or depending on your mailing
list subscription settings, through daily message digests or automated
notifications from the mailing lists.*
More information about the mapguide-internals
