[mapguide-internals] Problems to Build MapGuide OpenSource 3.1.2 and FDO 4.0.0 for CentOS 6 and 7 with 64 bits
Luiz Marcio Viana
luiz.marcio.viana at globo.com
Thu Jan 14 13:28:04 PST 2021
Hello Jackie,
How are you?
I have used MapGuide OpenSource since the first versions, and I have
identified some problems to compile that software from the source code
after the release 2.5.
Some problems take the activity of compile the MapGuide OpenSource 3.1.2
with FDO 4.0.0 on a CentOS 6 or 7 with 64 bits a task dificult to execute.
I have also identified some problems with the compilation script when I
build the software for CentOS 6 32 bits.
SUGESTION: In the past, the final source code used to build the MapGuide
OpenSource releases was available for download.
Thanks,
Luiz Marcio Faria de Aquino Viana, M.Sc.
TLMV Consultoria e Sistemas EIRELI
http://www.tlmv.com.br
+55-21-99983-7207
Em 10/15/20 6:18 AM, Jackie Ng escreveu:
> Hi All,
> I've put up the second preview release of MapGuide Open Source 4.0
> https://trac.osgeo.org/mapguide/wiki/Release/4.0.0/Preview2/Notes
> This release is for *testing purposes* and use in a production environment
> is not encouraged.
> Preview 2 finally includes the Linux build that was missing from the
> previous preview release. One important note for our Linux users is that
> our Linux build of MapGuide now only targets Ubuntu 16.04 LTS 64-bit and
> that Java support is currently broken on Linux.
> We recently upgraded our bundled Tomcat to the 9.x series and required some
> config changes. Java support works on Windows, but is failing on Linux and
> we lack the proper resources to debug and investigate further. All we know
> and suspect so far is that it is some missing security-related
> configuration needed since Tomcat 8 or 9, but we don't know what that
> missing configuration is and as a result all our .jsp requests cause Tomcat
> to return HTTP 403 forbidden errors, rendering our Java viewer and
> associated code samples to not work out of the box.
> If any of you have any idea what the problem is (by installing the preview
> 2 Linux build into your spare Ubuntu 16.04 VM or docker container and mess
> with the existing configuration to get the Java viewer into a working
> state), please let us know of your findings in this trac issue (
> https://trac.osgeo.org/mapguide/ticket/2828) or by posting your findings to
> the mapguide-users mailing list.
> I will be resuming the MapGuide 4.0 new feature blog series shortly as
> there are still many new features to be covered.
> - Jackie
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
