[mapguide-internals] Fwd: Problems to Build MapGuide OpenSource 3.1.2 and FDO 4.0.0 for CentOS 6 and 7 with 64 bits
Luiz Marcio Viana luiz.marcio.viana at globo.com
Mon Jan 18 01:12:41 PST 2021
Hello Jackie,
How are you?
I will check the NEW docker-based build system.
https://github.com/jumpinjackie/mapguide-fdo-docker-build
Thanks,
Luiz Marcio Faria de Aquino Viana, M.Sc.
TLMV Consultoria e Sistemas EIRELI
http://www.tlmv.com.br
+55-21-99983-7207
Em 1/18/21 5:27 AM, Jackie Ng escreveu:
> Hello Luiz,
> I am only contactable by email and through these mailing lists. I don't do
> Google Meet / Zoom / Social Media / etc.
> Regarding your Linux build problems.
> I use Vagrant to spin up VirtualBox VMs for Ubuntu 14 and CentOS 6 VMs to
> build MapGuide within them. I don't produce official builds of MapGuide for
> Linux any other way because up until MGOS 3.1.2
> The vagrant environment can be found here:
> https://trac.osgeo.org/mapguide/browser/trunk/Tools/Vagrant
> Which you can check out yourself from SVN like so:
> svn co https://svn.osgeo.org/mapguide/trunk/Tools/Vagrant
> Please note however for MGOS 4.0 (what trunk is currently), we have
> completely overhauled how Linux builds are done. It is all CMake-based and
> builds are done within docker containers to ensure the same repeating build
> environments every time.
> The current source in trunk MapGuide and FDO is *no longer buildable with
> autotools* and we now require you to use CMake. Whatever autotools configs,
> makefiles or wrapper shells scripts currently in the MapGuide/FDO sources
> are no longer maintained and will eventually be removed in the future.
> The docker-based build system is a work in progress here:
> - Jackie
> Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Internals-f4209935.html
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
