[mapguide-internals] MapGuide Open Source 4.0 Preview 4 available
Jackie Ng jumpinjackie at gmail.com
Tue Nov 8 03:11:10 PST 2022
Hi Crispin,
Good to hear the windows installer works on Windows 11. Release notes
updated.
About updating GDAL. The problem right now with updating to GDAL 3+ is the
(now) hard dependency on PROJ, which means to update to use GDAL 3+, we now
also need to:
   1. Add sources for PROJ
   2. Add sources for sqlite3 (because this is a hard dependency of PROJ
   and we can't rely on the sqlite3 used by the SQLite provider as its
   internals have been heavily modified to suite the needs of the FDO provider)
   3. Both GDAL 3+ and PROJ require CMake 3.10+ to build and we now have to
   build this with CMake on both Windows and Linux
   4. We might as well get FDO to build with CMake for both Windows and
   Linux at this point.
In short, there is *lots of work* involved. What would help us a lot on
this front is if we can get FDO to leverage vcpkg for all of its
thirdparty libs. Using vcpkg means we can completely eliminate our internal
FDO thirdparty sources as all the libs we're currently using can be
acquired by vcpkg. However, adopting vcpkg means we actually have to get
FDO building with CMake on both Windows and Linux (point #4 above).
So as you can hopefully see, there is not only a lot of work, but also a
lot of tradeoffs to consider as well.
- Jackie
On Tue, 8 Nov 2022 at 06:55, Crispin Hoult (TrueViewVisuals) <
crispin at trueviewvisuals.com> wrote:
> Hi,
> Thanks indeed -- custom installer settings and all seems OK so far
> (Windows 11 to add to the compatibility list == Windows Server ????)
> One comment on the release notes and actions before RC, even at this late
> stage.
> The comment on the GDAL version 2.4.4 is that is provides better swap with
> externally copiled GDAL from some of the other online providers.
> Now GDAL is v3.5+ and 2.4.4 is getting on for 3 years old and at the end
> of the 2.x release chain there is a risk of any future vulnerabilities not
> being support/patched and not being able to swap out for a
> new/alternatively compiled GDAL.
> How big a deal would be updating this component?
>  Crispin
> -----Original Message-----
> From: mapguide-internals <mapguide-internals-bounces at lists.osgeo.org> On
> Behalf Of Gordon Luckett
> Sent: 04 November 2022 12:09
> To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
> Subject: Re: [mapguide-internals] MapGuide Open Source 4.0 Preview 4
> available
> Thanks Jackie,
> I have updated the https://trac.osgeo.org/mapguide/wiki/WikiStart page to
> reflect the release of Preview 4
> On Fri, Nov 4, 2022 at 6:44 AM Jackie Ng <jumpinjackie at gmail.com> wrote:
> > Hi All,
> > After a long and arduous development journey, the 4th preview release
> > of MapGuide Open Source 4.0 is now finally available!
> > https://trac.osgeo.org/mapguide/wiki/Release/4.0.0/Preview4/Notes
> > This release is for *testing purposes* and use in a production
> > environment is not encouraged.
> > This release overhauls all of our language bindings to now be
> > generated with the official version of SWIG instead of our ancient and
> > heavily modified copy. This means we are no longer shackled to PHP 5.6
> > and for this release, we are now bundling PHP 8.1.
> > Use this release as an opportunity to get your MapGuide applications
> > ready for 4.0 final release by getting your code working against the
> > new bindings and doing whatever migrations needed.
> > These new language bindings are the last major feature in the 4.0
> > timeframe. It's all bug fixes and (any required) thirdparty library
> > updates going forward. So I am expecting a relatively short Beta > RC
> > > Final cycle after this.
> > - Jackie
> > mapguide-internals mailing list
> > https://lists.osgeo.org/mailman/listinfo/mapguide-internals
http://themapguyde.blogspot.com
More information about the mapguide-internals mailing list
